$250 OBO
http://www.4x4xplor.com/lod/proddeta...prod=XTC1011-T
I have a LoD brand rear bumper and tire carrier for 76-86 CJs (I can get you measurements to see if it will fit whatever jeep you may have).
I have had it for 5 years and it has no major damage and functions 100%. The only reason I took it off and am selling it is that I am stretching my CJ and am going to build a rear bumper/crossmember for the springs to mount instead of modifying this one.
This is a great bumper and carried my high lift and 35" spare all day with no problems. I won't go over the specs b/c you can read about them in the attached link. . . http://www.4x4xplor.com/lod/proddeta...prod=XTC1011-T
It does have some minor blemishes.
1-Powdercoating missing and dull near the hinge and latch area (see pics, pretty minor)
2-Two 1/4" holes in bottom left of bumper for license plate (see pics, pretty minor)
3-2 1/2" holes in hinge frame where I had some other stuff mounted (see pics, covered up when spare is mounted)
4-The two lower mounts that bolt the bumper to the spring hanger with one bolt on either side have been cut off b/c I was running aftermarket springs and hangers and so these mounts would not work for me. However, this bumper is still SOLID. For 5 years I still pulled my jeep out by the bumper and could jump on it no problem with no separation from the frame. This is accomplished b/c of the supplied frame tie in brackets (seen in the pics) which are ridiculously strong.
As far as the holes, if it will make the sale then I will weld them up for you but be aware that the heat will prob. ruin the powder coating in that area. If they bother you that much then my recommendation is to find some black plastic plugs to fill them in with.
Also I have the stock 5x5.5" mounting plate with studs/nuts or for $10 more I have a universal mounting plate without studs/nuts that will allow 5x4.5", 5.5x5.5", 6x5.5", 8x6.5" bolt patterns. Let me know which one you want and I'll weld it up.
I am asking $250 which I know is way cheaper then other bumper/carriers on the market. Also the suppliers website says there is a 4 week wait if you order a new one through them. This bumper is available now.
I can meet anywhere in the DFW area or will be making a run down to the College Station area in a few weeks.
Thanks!
