My Truck is for Sale.I think I found a buggy I want (or want to start moving towards).
Thing will Wheel. It truly works, dependable, reliable, when the tires are aired up I have had it at 65 no problem (it was just chilly with no windshield. Heat and AC work, just a smashed cab is all. I probably have, with purchase price $22K - $23K in it. You can see the list of Parts below, no expense spared, 14K just in the parts. I love it but ready to move on.
Has regular doors and tube doors, will obviously include both. Thing has tackled some of the hardest terrain in Clayton including Green Momba and Green Momba's Extension (with my driving skills!). Will crawl super low.
Put together a list of just the parts on it:
Drivetrain
FROR Tacoma Crossmember and Skidplate Combo $349.00 http://frontrangeoffroadfab.com/nfos...products_id=34
Marlin Crawler Built Tacoma Double Transfer Case Setup, 4.7:1 $1,995.00 http://www.marlincrawler.com/transfe...unit-mc09-t360
FROR Tacoma T-Case Twin Sticks $189.00 http://frontrangeoffroadfab.com/nfos...products_id=36
Axles
Tacoma Custom Width Diamond Axle Housing $900.00 http://www.diamondaxle.com/front_steering.htm
Custom Length Longfield inner axles $330.00 http://www.longfieldsuperaxles.com/p...LE-SHAFTS.html
Longfield Birfields $430.00 http://www.longfieldsuperaxles.com/p...-BIRFIELD.html
Tacoma Brake Mounting Kit $99.00 http://frontrangeoffroadfab.com/nfos...roducts_id=136
Front Toyota 8" V6 3rd With 5.29 Gears, Detroit Locker and Solid Pinion Spacer $1,124.00 http://eastcoastgearsupply.com/i-157...-8-v6-3rd.html
Rear Tacoma Non ELD/ T100/ Tundra 3rd With Detroit Locker, 5.29 Gears and Solid Pinion Spacer $1,235.00 http://eastcoastgearsupply.com/i-788...undra-3rd.html
Steering
FROR Full Crossover Steering Kit $399.00 http://frontrangeoffroadfab.com/nfos...products_id=93
All Pro Rebuilt IFS Steering Box $399.00 https://www.allprooffroad.com/pickupsteering/246
Suspension
FROR Tacoma Solid Axle Swap Kit $199.00 http://frontrangeoffroadfab.com/nfos...products_id=38
Diamond Spring Perches - $40/pr $40.00 http://www.diamondaxle.com/parts.htm
Diamond U-Bolt Flip Kit - $69 per axle $69.00 http://www.diamondaxle.com/parts.htm
All Pro 5" Front Long Travel Leaf Springs $269.00 https://www.allprooffroad.com/pickup...kupleafsprings
Front Bilstein 14" 5125 Shocks $158.00 https://www.allprooffroad.com/pickup...ckupshocks/301
Trail Gear Universal Shock Hoop Kit $52.00 http://www.trail-gear.com/shock-hoops
Tacoma Steering Box Mount & Frame Plate Kit $149.00 http://frontrangeoffroadfab.com/nfos...products_id=46
Custom Rear Alcan Leaf Springs for pre 97 Tacoma $349.00 https://www.allprooffroad.com/9504ta...504leafsprings Don't remember price so going with All Pro lesser springs for price comparison
Rear 5125 - 12" for Lifted Applications (BE5-6249-H5) $158.00 https://www.allprooffroad.com/9504ta...rearshocks/301
All Pro Rear U-Bolt Flip Kits $49.00 https://www.allprooffroad.com/9504ta...04uboltflipkit
All Pro Short Shock Mounts $29.00 https://www.allprooffroad.com/9504ta...504shockmounts
Armor
Rocktek Custom Front Bumper $499.00 http://www.rocktekcustomz.com/
Rocktek Custom Sliders $359.00 http://www.rocktekcustomz.com/
4x4Inovations Tube Doors - 95.5-04 Tacoma Tube Doors $215.00 http://4xinnovations.com/p-TD03.html
Tube Bed and Roll Bar Custom $500.00 Custom Made
Wheels and Tires
Trail Worth Fab 12 bolt Double Beadlocks, Powdercoated Hammer Black with Pressed Centers, 6x5.5 bolt pattern and PVC Inserts. Full Rock Rings $1,219.80 http://www.trailworthyfab.com/-175-1...l-Special.html
Pitbull Rocker Radial Tire 37x12.5 R16.5 $1,559.80 http://www.4x4groupbuy.com/store/pit...5-p-11493.html
Accessories
Superwinch 8500lb Winch with Synthetic Winch Line $449.99 http://www.northerntool.com/shop/too...2430_200422430
IPF Lights $99.00 http://www.trdparts4u.com/scripts/pr...?idCategory=21
Modifications Total $13,871.59
. Sorry Sam the cab I knew of sold a long while back.
