Not sure why I never posted this over here... I copied it from another forum, so if anything is missing just ask questions.
Has the following:
Forged 1350 yoke
High steer arms/tie rod behind the axle
Uses 8 ARP studs on the arms rather than bolts.
Calipers/pads/rotors/kingpins all brand new 2 years ago. They have less than 100 miles on them. I wheeled it 3 times since the dana 60 was installed and parted it out last year.
I can't remember if I welded just the spider gears or welded them to the carrier. Has 4.10's, but the threads on the pinion nut are fubared. If it's taken off again, I doubt the pinion would be reusable.
Does not include the tie rod/drag link and brake lines that are in the pictures...
Price is $1200 located in bryan.
Edited to add pics:
I dragged the axle outside knocked the surface rust off the rotors and washed it. I might get some better pics tomorrow at lunch. It was getting late when I took the pics.
