it looks like brian is going to keep the blazer in tact for one last run..... so no secret buggy but there will be his rig and my cj.
Looks like I'll be leaving from Austin now
jason, your sig says 37" mtr's i thought you were running hummer 37's. those are wrangler mt's not mtr. just curious
hey colman, i noticed in your sig it says that you have tbi efi, but i thought you were running a carb? no big deal, just saying![]()
actualy the tbi is back on the jeep. i did that right after i got back from alto... i just didn't have time before. to many other things like brakes and clutch to attend to sooooo....... fail on your part for making assumptions.. you know what happens when you assume dont' you?
i didn't say the swap back to tbi was finished, but it has been started and will be done by clayton....unbolting that ****ty carb and getting the tb unit bolted back on felt good.
Getting pumped for this trip as the weather is getting cooler. If you have never been to Clayton, it is some seriously great wheeling. All newbs should try and make it.
