Page 185 of 211 FirstFirst ... 85 135 175 181 182 183 184 185 186 187 188 189 195 ... LastLast
Results 2,761 to 2,775 of 3159
Thread: Random Tech Questions
  1. #2761
    Why don't u take it back to Firestone?
  2. #2762
    Registered User heathermcc's Avatar
    Oct 2011
    College Station
    Quote Originally Posted by JB View Post
    we are taking it to car doc today per request of tommy to get the tires balanced
  3. #2763
    Maybe you can talk firestone into doing it for free since they didnt do it right the first time.
    F*ck off cj.
  4. #2764
    Confused. If Firestone did the alignment, and you have an alignment problem, then why haven't you taken it back to them? Cardoc has an alignment rack as well. Have them check the alignment as well describing to them the problems you are having.
  5. #2765
    Oct 2011
    College Station
    we dont know that the alignment is the problem
  6. #2766
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    It sounds like you have a lot of people who don't know what they are doing, doing what they do best.
    If is a brake problem alignment wont help. If the caster is not right alignment wont help. Get the caster issue fixed and then go from there. If the caster is wrong then its not going to drive right.
  7. #2767
    Oct 2011
    College Station
    this is from the alignment firestone just did.
    there was a problem before the lift, where there was no caster issue, so we dont see how it can just be the caster.
  8. #2768
    it's not the caster. Find some better tires. Then replace all control arm bushings and ball joints while inspecting bolt holes. Then make sure shocks and steering stabilizer are working properly. Then brakes and bearrings. Then inspect for bent axles. Then if it still wobbles realize it is a jeep and sucks, JK.
    Also I heard your trac bar bracket was drilled out with a step bit, if it's wallard (sp?) out you're ****ed.
  9. #2769
    DFW
    Take a page from my book, yell at it, cuss it, convince yourself the loss you are about to take on selling it is no big deal, sell the damn thing and buy something else.
  10. #2770
    Oct 2002
    Poth, Tx
    Borrow a set of tires that are known to be good.
  11. #2771
    Oct 2011
    College Station
    Quote Originally Posted by eight View Post
    We are running ryans 33s on the front. Didn't change anything. And his doesn't death wobble
  12. #2772
    Front and back tires
  13. #2773
    Fixed it
    Me, Evan and Ryan went over the whole thing and threw the puss at the trackbar bolt. That heim has less than 20 miles on it and it's already loose.
    Rear track bar bolt was held on with 2 of the 3 bolts. So it was all over the road and we welded it on.
    F*ck off cj.
  14. #2774
    no more death wobble......it did conquer the hill that spooby broke on......after a running start
    I think the track bar bolt was the problem. The lower control arm bushings looked shot but I looked at the ones on my jeep (which has no dw) and they were equally sloppy.
    Edit: this was a reply to Karl.......which he somehow posted after my reply to him?
    F*ck off cj.
  15. #2775
    Results?
