What time Saturday? I'll be in midlo
why are you stuck on using a stud, is there not a way to make it use a two tabs and bolt.
I want that sleeper look.
Let me think about the tabs. That could be easier. You got that shear working yet?
Doable. front or rear?
don't know. whenever. i have tomorrow off also.
Came up with this during lunch, I think this will work if the gas line clears.
cut it off at the side gusset you would loose one bolt but it would look better or just make with out the bolt hole part and just weld the side gusset part to the frame rail. i think you could make it much smaller
Its that size because its symmetric. Only 3 of the 5 holes are used per side.
make a right and a left to make it smaller then it's to big looking to me
much better! u sure the shock body will clear around the bolt tabs when extended? u plan on sleevin those bolt holes in the frame?
looks good to me send it to production. Do you do anything with aluminum plate?
Can u print that off as paper templates to check the fit? I didn't realize this used stock bolt holes
yeah, I was planning on doing that tonight with the 1:1 plot
Got the fronts figured out
that o-ring is where it sits at ride height
