Respek
Holley Pro Jection, Weld wheels, 15" street tires
Apparently I'm on a fuel delivery saga here.....decided the motorcraft 2bbl is sufficient.
$150 obo
Has everything except wiring harness. (uses mostly tbi sensors)
:toast:
Will trade for sterling 10.5 or 10.25 5:13 gears
I had these wheels on my bronco, switched to some h1 beadlocks. I can't find these online, I was told they're pretty $$ though.
Asking $300 obo for the set. One has a set of holes wallowed out but i never had any trouble with them. (only the 8x170mm holes are wallowed out)
16.5" Two bolt patterns 8x6.5 and 8x170mm. 14" wide. Calipers were rubbing on the back of a couple of them. 5" backspacing
They shine up real nice bigok
:toast: Open to trades
Also, some tires that came off my trailer wheels. They were on a bronco, not sure of brand. About 31"......good tread. $80
Originally Posted by
Sharpe
F*ck off cj.
- You may not post replies
- You may not edit your posts
Forum Rules
