This thread likes turtles.
Being an owner of multiple kickers during high school, I must say that they are excellent subs. Unless you are into metal, in which case no sub is good because they all get blown
Did you read the pamphlet in the sub box on the proper port volume?
ryno this is what I was talking about regarding the DVD player trim piece. There are interchangable surrounds for the 2 different roof lines of a series 2, but they never made one for a series 1 so it'll have to be kustom.
no ports. sealed is way easier and better sounding for most speakers
If that was true, why would anyone build a box with ports?
ported boxes are for letting your neighbors hear the bump, sealed boxes are what you would find in any higher sound quality system
Boom
what is the nominal impedance seen by the amp in this setup?
why are you putting all this together if you can't figure that out?
