well I got it running, all it needed was a new fuel pump, plugs, wires and I upgraded to HEI ignition since it cost the same as replacing the old ignition parts that I needed and now it does not run using points. I picked up DaveO's old fuel tank in trade for my stock springs. I got the lift on it. Now all I need is new tires, a windshield frame, some seats and it should be a good driver. Then it will be the task to get it street legal. Pictures to come tomorrow when it is light out.
- You may not post replies
- You may not edit your posts
Forum Rules
