And here is a video of it running with the straight pacesetter header....
Here it is after I put the High flow cat and the magnaflow muffler at 2.5 inches, to tell you the truth I am disappointed, I wanted it louder and I can barely hear it in the cab.....
No updates or work on the mj today because other things became more important....... Such as meat and beer! Sunday funday anyone?
more to mention, not documented was the install of the new water pump, high flow thermostat, new thermostat housing, new valve cove gasket, new front u joints, new front slip yolk, new vacuum harness, new air filter, coolant flush.
ok guys, so I got the mj back together am my brother surprised me with this for my birthday, a flexalte transmission cooler and B&M trans temp gauge.
Went to the junk yard and found a grill for cheap. not sure if Im going to use it yet....
Decided after the motor mount and header install that I needed a tool box so I went out and bought a birthday present to myself!!!!
Jeep + Truck = Pants Creamed. Comanche, J20, Gladiator, whatever... all awesome. If you want more volume, try running a Cherry Bomb glasspack. I know, I know... it carries a stigma, but it will sound great.
his jeep tried to pull a sam's colorado today
Cool rig. Hope to see it out on the trail
