1980 Toyota Asking $1200
Here's the bad:
* 22R engine blown, thru a rod thru the block
* Body is extremely rusty
Here is what it comes with:
* 35" Boggers
* Toyota mini truck axles with 4.38's front and rear welded, front has trusses welded to strengthen the axle
* New brakes front and rear and new booster
* "Bellfield" 27 spline axles, these are not longfields, but are an upgrade from stock birfierlds
* Hi Steer - Beefy hi steer arms, 5/8" heims, 1.5" tube drag link and tie rod, FJ80 tie rod at pitman arm, power steering
* Front drive shaft has trail gear extended slip shaft
* Marlin Crawler doubler, stock gears in front and rear case
* KC Lights
* Fuel tank is a boat gas tank
* 2 plastic racing seats
* Extra parts - Extra rear axle with 4.88 gears, 2 complete front spindles to hubs, 4 stock birfields, complete set of front axle shafts
I was building this, took it out this weekend to see how it would do. It worked great, then got home and was pulling it off the trailer and the engine thru a damn rod. I'm tired of working on it. Buy it, put a new 22r in it and wheel it, or cut it up for parts, I don't care just get it out my yard. Pretty firm on the price, This cheap, I could part it out and make more...
Located in Crosby, Tx 77532
-Karl two 8 one - 755 - six 778
