Results 1 to 15 of 42
Thread: Death Wobble Thread
Threaded View
  1. #6
    Hellbent's Avatar
    Aug 2010
    I did a lift on a TJ a few weeks ago and in less than 20 miles the track bar relocation bolt hole wallowed out. I just welded the bolt into place and it killed the death wobble. So that is possible if you have done that mod. Mine never had an issue with that but I only had one run on it before I got rid of those axles.
    I am sorry for whoevers jeep you did this too... Cause it's obvious you're the best welder around...
