it must be better, it says so on the box
Exhaust tubing and a 6637 filter from napa work great on my truck. If you wanted to get fancy i guess you could fab a box with some thin aluminum and some pop rivets.
But you're not making any bends with the exhaust tubing, correct? As for the box itself it will probably be some thin aluminum, but it's the turbo to filter routing I'm unsure of? If only the cummins had the battery and filter setup of the 7.3 it would truly be the perfect engine...
No bends but any exhaust shop should be able to make whatever bends you need. It's 4" tubing.
Or if you want to get extra fancy, figure out what you need and order mandrel bent stainless from summit.
silicone tubing if you want to be extra fancy
http://www.siliconeintakes.com/
My truck has some really big 2" exhaust then.
quality and longevity should be as good as any of the silicone pieces on your inter cooler piping. If you search around there are several different sites selling the silicone intake parts but since you are not planning on using them under any pressure you don't have to get anal about layers and all of that.
