You should find a bumper that fits first. Then maybe quit fuggin with it, drive it, and work on your trail rig.
working on a bumper that fits, I'm just borrowing Evans.
It's already rice enough. the 40" bar fits inside the bumper....
why does an f350 need to flex?
Does it matter? It was a curious question. I'm not spending money on leaf springs.
I would try and find another color of spray paint to match that grille to your truck.
Anyway you can change the thread named to "Steamed Rice" it's much more appropriate that Tug.
the spray paint matches perfect, the clear coat however ****ed it up.
Since travis is ordering ricer stuff on his truck, i figured I had to do something to my truck.
Got a piece of aluminum for my skid plate today. That will finish my bumper for now.
I also ordered a Wicked Wheel 2 that I'll try to get installed sometime this week if I have time. That should give my truck some more power and cure some of the black lung. It also comes with new turbo o-rings which I think mine are leaking, and I'm going to delete the exhaust back pressure valve as mine is clogged and gets stuck closed from time to time.
7.3!!!!!
The wicked wheel is snake oil
i like snake oil. Read up on the new wicked wheel. Not the same as the first one.
This snake oil is an awesome improvement. I don't have boost numbers but there is a lot more a lot sooner. The turbo whistles now instead of whine and the CELL for overboost comes on often which it never did before. I highly recommend this to anyone with a 7.3.
