The plan is just to basically copy Karl's crossmember with two cradle bars. One will be on the adapter between the 203 and 205, the other will be off the rear bearing plate. Instead of doing a separate tammy crossmember I'm gonna make a 180 bend and weld it to the front tube and bolt the tranny mount to it.
