Did you rebuild the cluster yourself? It turned out good.
I have a running/driving truck again, well kinda.
Rebuilt rear suspension, rear Eaton HO72 axle, and 2 piece driveshaft (new u-joints and center support bearing).
Repainted the upper dash black and the dash face a matching interior grey. Also replaced the light switch, dimmer floor switch, ignition switch, cigarette lighter and the rebuilt instrument cluster with working lights.
New battery box and hold down. All new wiring harness for the entire truck. New battery cables and grounds. New voltage regulator and resistor. New paper element air filter.
1. Wire you up an inverter.
2. Plug in Hairdryer and duct tape to intake
3. ????
4. Profit! (i.e. instant boost!)
leafblower
That thing is in serious need of some more paint in the engine bay and some cloth style wire loom.
lots of progress. keep it up
Somehow I missed this until now.
Is the bear? Is the guy?
I don't understand why you would use seam sealer in the middle of a panel. If you are worried about the weld area being sealed, you should use a poly primer, or an epoxy coating.
Where are you moving?
I was wondering about the seam sealer, too. I'm no expert so I didn't say anything. Figured you had researched it somewhere.
MUCHO BUENO! That is starting to look like a truck again!
