Toyo comes in a 37 e rated tire too I think. Ill look into them tomorrow.
I am liking my Hankook mud terrains on the dually so far. Have held up well to the jobsite and pastures this winter. Were very cheap for a 265/70/17 also.
Do some diagnostics before you throw money at it.
Also not a part I would be looking for someone to have laying around.
I'd skip that. Its probably more worn out than yours. I would either get a Bosch reman or a t500, and only after I knew there weren't any high pressure oil leaks.
They can easily be swapped from truck to truck. Takes a extra deep 18mm to get off tho
No, now you really need to replace your headlights. The 02-04 lights are 25 each on rock auto, they bolt in and use the same 9007 bulb.
or u can cut a lil and fit 05 up lights for a lil more and get way better lighting
They do cost quite a bit more, and you have to get the harness adapters, and new bulbs. $50 or $300?
