You can prolly adjust your front arms a fair amount to help with the pinion angle.
Tommy Matheaus '06
210-323-2546
2004 F-140 4x4 DD
1990 F-150 4x4 in the works
You can adjust it a little, I would be more concerned about adjusting the angles to keep the caster correct.
Get it together and see what the angle looks like. I don't think you will have a problem but 8.5" is a lot of lift.
Sorry I posted that at work and could not see the pics. I mean I'm a dumbass, but not that much of a dumb ass.
Like freight on and tommy said, put it together and try to adjust the lower arm short, see where you are at. A cardan joint 1330 will take a lot of angle and should suffice, but a cardan joint on each end seems vibrolicious, I assume that is what you mean by double cardan.
Like Travis said and you have read on the interweb it will effect caster, but I would think you could find a happy medium.
I'm hoping so but I have been told it won't be enough from some xj guys. But y'all are right. Will just have to get it on and go from there. If only I could get some days off work now to get it going.
Nothing new to mention about the mj right now. Have been hitting the books hard and will be graduating in about a week. In the mean time I have been looking to trade in my 2008 ford fusion as soon as I get a job for a H3T. What do yall think. I am not considering anything less than the V8 option. They are hard to find and have been looking for the past year.
I would just go buy a chevy 1/2 ton 4x4, v-8. You should be able to get that new or 1 yr old below that price range.
I laugh a little every time I see one of those somewhere. A regular Chevy pickup would be a much better option.
In all seriousness those things suck. They are on the same chassis as a colorado, so even though you have the bigger motor, you do not have the suspension or frame to handle anything bigger than a mini truck can. I owned a colorado and it was a massive pile of ****. The interior in H3s are still small and not very roomy, the mileage is terrible, and you still have to look like a Dbag in a mini version of a vehicle that was cool 2 generations ago.
Like frick said, buy a half ton 4x4 chevy. They are bigger, will probably get better fuel mileage, look better, and you can handle towing more with it.
Also, if you knew the last H3 driver that was in the club, you would seriously reconsider your opinion.
