Some stuff from my old truck that I don't need anymore.
D70U complete axle with I think 3.50 gears and open carrier - $150
Full size bronco starter kit - $400
79 D44 Complete lock out to lockout, radius arms, coils, coil buckets, track bar, shocks, shock towers, radius arm brackets, steering parts, pitman arm, steering box 3.50 gears in an open carrier long side shaft is chromo
New radiator should fit 67-79 ford trucks from advance, only filled with fluid and idled the truck around a bit - $60
Running 360, was told it was rebuilt not too long ago when I bought it. complete motor, has AC compressor, ps pump, no alternator unless you want to buy my 3g from me, has dui distributor hei ignition module and for tfi coil - $150
FE pattern C6 core, I know first gear and reverse are good, haven't driven the truck fast enough for it to shift - $150
35x12.50r16.5 BFG all terrains, these are older tires but have some tread left and and have some mild weather cracking. I wouldn't be bothered to run them on the street. These come on 2 8x6.5 and 2 5x5.5 wheels - $100
