Pimp, oh and iroks suck!
Need to body work the old bolt hole a little more.
Did they come with a man sized front axle to?
Rims look nice!
Cracked the can on the PS pump in Clayton (which was the reason for the whining pump/vomiting fluid). Cracked at the upper fitting. PSC rebuilt the pump and replaced the can and are shipping it back to me.
Also sheared another d-44 high steer arm stud off. . . . same side/same stud as before. Pulled the knuckle off and worked the broken stud out. Damn things keep loosening up. Went ahead and replaced the balljoints and spindle bearings since I was in there. Replaced the high steer studs, cones and nuts and red-Loctite them into place.
You are not supposed to bottom the studs out. Only install the studs into the top of the knuckle by hand. Leave a 16th of slack or so from tight. They are supposed to be in tension, but not torqued into the knuckle. The non-threaded portion is so that the high steer arm and stud have a tighter fit than if it were just threaded all the way.
That smooth part is the middle of the stud. The other treaded portion is broke off
Here is an earlier pic that shows a comparison.
http://www.tamor.org/forums/showthre...l=1#post300795
