Its pretty dead on level now. I had bought some adjustable shackles thinking that after the lift in the front the rear would be sagging a little and it would need some more lift in the back to get it level but looks like it leveled out perfect without them. You can tell from the picture that the front axle is sitting a little more back than it should. Need to adjust the upper arms to get the pinion angle right and the lowers to push the axle out more.
