ummmm.....maybe
user friendly
Austin, when I said "crack", I meant that the case is split completely through on the back of the case between the rear output and coverplate for the front output. Also, I'll be twinsticking the new one, so there's a possibility that I'll foul up a shiftrail in the process. Worst case, you'd be getting a 205 with a broken case that can be shifted into front high and rear low, and vice versa...and dissasembled.
If this still sounds appealing it's all yours.
we're starting our own junkyard here anyway...and i've got nothing but time on this project...i'll take it.
dont mess up my shifter rails!
did you get it without incident? Did you figure out his name for me?
user friendly
Yeah, no problem picking it up, thanks a lot. His name is Steven, IIRC.
- You may not post replies
- You may not edit your posts
Forum Rules
