is there an egr valve that's cheap and/or easy to replace?
I'd start there
Think you could have gotten a batch of bad gas? Maybe top off your tank and hit it with some of that octane booster stuff
so has any one heard this noise? Cause they is a big difference between an engine miss and valve train/wrist pin problem.
egr valve and cheap not so much. I think for the one for the bronco/mustang motor is like 80 bucks at horeilysOriginally Posted by uglyota
egr valve isnt your problem. it'll make it run terribly if it gets stuck, but wont make noises. i wouldn't worry about it until you get everything else niched first.
if it is a ping (bad gas) and it's that bad, and you have been driving it for a while now. it's probably not a ping anymore. if thats the case then it may be a wristpin because the piston top has burned away and its melted the wristpin.
just thinking out loud, could be a spun bearing
I think it is a wristpin. I'm going to have a guy listen to it friday morning and see what he suggests. If I need a new engine what are some good places I can call around here to get prices?
ok, two more ways to troubleshoot mechanical problems:
if you suspect its a bearing or wristpin:
sounds cooky but works (usually). remove one plug at a time and crank it over or drive it around the block. when the suspect noise ceases, thats your cylinder with the bad bearing/pin
if you suspect valvetrain problems:
such as a stuck lifter or valve out of adjustment. get a screwdriver (put one end to your ear and the other to the engine, preferrably the blunt end to your ear and the sharp one to the engine), peice of hose, or a stethescope and listen to the valve covers while its running. move it along the valve cover and where it gets loudest is the problem area. i picked up a auto stethescope at o'reilly's once to see which of my injectors were stuck. they're great to have to troubleshoot engine noises. they have a probe on the end instead of the pad thing doctors have.
to get your engine rebuilt: vilas
to get a pull-out motor: doggett auto salvage (i think thats the name, the one on the SE corner of the hwy6 and 190 intersection)
to get a new engine: the dealer![]()
where are you from?Originally Posted by aggieblazer07
nothing agienst vilas but i havent heard very good things about them(no offense austin)
Steven W
02 Dodge 2500
i had a head for my old 258 rebuilt at napa in bryan. they do good work, i just didnt like the guys' attitudes there.
I think someone is going to have to hear this "noise" to understand what it is. are you in cs?
until about 3. Then I'm heading home for the weekend
i'd like an explaination of that. between the guys there there's probably 50+ years of experience building engines. cooks doesnt do very good work. they cut corners and their method of cleaning a block fills the water jackets w/ shot peen, which they dont try very hard to get out. hows that for a cooling system?Originally Posted by StevenAg03
Originally Posted by BigRedFord04
thats what i hear from most of the mechanics here
Steven W
02 Dodge 2500
what is what you hear? from mechanics where?
I remember we were getting a couple of ball joints pressed into some 44 knuckles one time in CS and we were looking for someone to press them in since we didn't have a press. Took them to Cooks, and I **** you not, they said, "what are those?" Then, they said they "thought" they could do it, so we dropped them off, came back a half hour later and they were like, "well, we couldn't figure out how they were supposed to go in there." We proceeded to take them and walk out and drive directly to Vilas where they pressed them in while we waited. I wouldn't trust Cooks to make me a peanut butter sandwich.
