Welcome to my buildup thread!
I decided since everyones got a buildup thread (it seems) that I want one too. I've got a great paying job, so i'll be sinkin' some money into the toy in the next few months. My goal is to make a toy that can tackle some wicked trails but at the same time, be part of the RRDH club...and be nice enough to drive daily.
Of course, i've 'built' it before, but it seems i run out of money before i ever finish something. So far it stands as a 1991 toyota pickup with a 350ci that never runs right and leaks like no other, th350 that is pretty much perfect, an np205, d44 front axle 4.1s, 8" toyota 4.1s.
My first question is: should i ditch the axles and go d60/14Bfullwidth?
Otherwise, the change will definately go something like this:
RND1:
-get the 350 completely redone professionally
-go propane
-new front spring hanger (drop truck 2" bring axle forward 1")
-lose rear blocks (lengthen wheelbase, move axle back a tad)
-gloss black paint/bodywork
-propane tank underneath bed
RND2:
-stang seats (neoprene covers)
-new carpet
-tint
-sound
-onboard air
RND3:
-all new brakes
-a/c
-bumper/sliders/winch
-possible d60/14B or toy t-case w/4.0s
-39" iroks or 38" swampers
this time i won't run out of money, and i will complete it and not cut corners.
Depending on the leniency of my new roommates, i might do a frame up rebuild...por15 the whole frame/axles...cut off excess weight. I might skip the d60/14B and instead put the money towards a th350/toyt-case adapter and go with a toy t-case with 4.0s. Undecided. Eitherway, i plan on getting it to a wheelable state asap and will not miss any tamor trips.
put it on any desktop dyno or the like...you lose like 50% of the power. have someone build your 350 into a GASOLINE fuel injected 383. I'm sure Fredo could cough up a few suggestions on how to do it. the stroker kit from Summit is only $1100 mr. moneybags. i say swap out the axles too. probably wanna go w/ a bigger xfer case, like a 205, but to do that you'd need a 465 to go behind your 383.
