not sure where its at, I'll look around tomorrow
My bet is the ICM, I had a bad wells icm on a junkyard distributor and it sucked.
check all the wiring connectors too, I don't think ford figured out the weatherpack concept until the late 90's
as to the crank sensor talk, there is none.
even SEFI mustangs and lightnings don't really have one, there is a smaller tooth on all eec4 distributors that tells it who's #1.
from ho'reilly's and at the expense of a couple burn blisters from hot engine, i changed it in their parking lot. it still ran like chit until i got home and cleared the codes. after that it ran like chit too until the computer had time to readjust to the new sensor. now it runs decent but after about 15 mins cruising the check engine light came on again. scanned the codes again....previously it was 122, 172, 173, and 212. 122 is TPS. 172 is O2 (lean). 173 is O2 (rich). 212 is ICM. this time it was just 173 and 212. so, i'll try replacing those two. gonna have to actually pay for an O2 sensor b.c. they only have one year warranty, but i might have a receipt for an ICM when i replaced it on my old Ford.
