Originally Posted by
agjohn02
ah, the threaded outside, tapered inside thing i tightened with a hammer and screwdriver? i was wondering that the other day about whether or not they made those with different offset. how much correction can you get out of them? are they all offset or are , say for instance mine, most of them centered so no matter how they are clocked they give them same castor and camber, i.e.- keep the ball joint centered? im getting mine aligned tomorrow and thought the only adjustments i had were toe in/out with the tie rod and different camber plates/spindle shims whatever.
