Whoa ****....that's not good.
whose TJ is that?
Troy I believe, so all bets are off anyway...
makes sense from everything that I have heard
yep, those stock cast third members suck - I'm not going to use one of those... That was Troys - from Matt driving it in a comp in Truckee CA - where Nick lives...
I ground / sanded my shaved D60 and made a diff cover today
Lee's rear Ford 9 is 62" wide. I could run some 2" wheel adapters and be pretty close to my 67" front - Sounds like my current plan.
finished product before paint and a little fine tuning
Cool. Now come do mine. How did you recommend I cut mine off (sans mill)?
Looks cool. I'm curious why you didn't go with the Dana thick diff cover.
weight!! every pounds counts!!!
looks good. Might want to shave that one bolt a little bit though
I should have bought one of those - it would have been a much better starting point - but I just used what I had. Should be fineOriginally Posted by AgDieseler
David, I would just cut it out with a cutting wheel or something, seems alot easier.
I changed the bolts to butten heads and that bolt now only needs minimal grinding.
Hope it seals!
Thats what RTV is forOriginally Posted by redcagepatrol
can you take a picture of it w/ the button head bolts, I wanna see how it looks. I could use to do it on mine cause the bolts are getting rounde off on the bottome
here ya go
7" grinder makes quick work of the lip. About 5 minutes. I think I get about 5/8" off the d60. And a 14 bolt has more to remove. You get a little more with Scott's method, but its more work.
