Page 1 of 2 1 2 LastLast
Results 1 to 15 of 26
Thread: Garage Shelves
    Garage Shelves
    Here you go Eric. I started the thread for you
    I use these shelves.
    They seem to work well except I had to wrap a rachet strap around the one that the axle sits on to keep the spreaders from bending and letting the shelf fall through
    Why didnt you put the axle **** closer to the bottom?
    Oh and BTW I have those same shelves covered with ammo at my mom's house, they are suprisingly sturdy.
    exiled no more
    Mar 2008
    Fort Worth, Tx
    mine
    mind the junk
    it said 500lb limit...i think i've got that on the bottom shelf (NP205 and a pair of heads)
    Quote Originally Posted by afroman006 View Post
    because then it is too hard to get too
    May 2003
    Htown
    i gave karl a shat ton of full metal shelves that i scavenged from global, they are nicer then the ones with the mdf that sits on top of 4 pieces of steel.
    So you loose, I win!
    Aug 2002
    here's what I plan on building, but 2'x16'x8' tall, I like the idea of using a dado on the uprights
    http://www.naturalhandyman.com/iip/infshe/infshe3.html
    look nice, seems like a lot of work. I had some that I build out of wood I pulled out of the dumpsters at A&M when all of the freshman through their lofts away
    May 2003
    Htown
    Probably need some diagonal cross braces at least on the ends. My workbench shook all over before i put them on and it was more heavily reinforced than those.
    Cheap plastic shelves from Home Depot. Lightweight, easy to move around. It could handle alot more weight than I have on them. Maybe not axles, but they are plenty sturdy and inexpensive
    exiled no more
    Mar 2008
    Fort Worth, Tx
    how does all the stuff not fall off???
    Got these from an old Advance Auto display....
    Super sturdy. I actually have bench weights on the bottom shelf. The wheels are nice too.
    Dallas, TX
    I have the Lowe's version of the one Creighton posted. They're made by Edsal so I figured they'd be pretty decent. I got mine this weekend on sale for Father's Day and they're already loaded. I'm working on my work bench this week so I'll post a picture of it when I finish the rebuild.
    http://www.lowes.com/lowes/lkn?actio...824&lpage=none
    wouldn't suprise me if they aremade by the same people
    Is the wood on those shelves very chemical resistant. Aren't they particle board? Had some at the shop I use to work at and if any oil or chemical spilled, they became very weak.
  15. #15
    Nov 2002
    Tx
    Built this a few months ago. Pretty cheap and took 2 hours to build. Each shelf is 2x8 with 1/2" plywood sheet. For a little extra sturdiness, I used masonry screws to secure it to the wall.
    I didn't build a shelf on the bottom (like the one above mentions). I figure why build a shelf when there's a nice floor already there?
