Results 1 to 8 of 8
Thread: Chevy Truck and car hauler trailer
Threaded View
    lowballing someone
    Feb 2005
    Houstonish
    2008 Big Tex 10cc trailer. 18 foot car hauler. 5200 lb axles with dual brakes and big ball. Toolbox w/ dual batteries, chains boomers, 8k winch on warn reciever, random things in the box. No sides but comes with some steel to make them. 3" angle iron on fenders so you can drive over them. Bought last july. $2600 w/o acessories $3000 with
    1998 Chevy K2500 ext cab short bed w/ headache rack and tool box. 140,00. exterior is pewter interior is gray. power windows, power locks, power mirrors, front bench, Vortec 355(30 over 350), nv4500, 241, 8600lb gvw 14bff rear axle w/ 4.10, 4" suspension lift. In last 4k miles have replaced almost everything. Rebuilt motor with new heads, small cam, water pump, injectors, fan clutch, hd radiator, tps, distributor, cps, o2 sensors, catalytic converters, dual 40 series mufflers, heater core(uninstalled), coolant overflow bottle, moog ball joints, tie rods, pitman arm, idler arm, cv shafts, rotors and pads, drive shaft u-joints, starter, ac delco plugs, wires, cap, rotor, 4x4 coupler, clutch, flywheel, clutch slave, master and line, super bright high and low beam headlights, ranch hand rear bumper, moto metal rims on 33's, radiator hoses, changed all fluids and more. I have reciepts for parts. The only thing wrong is the heater core is uninstalled and i haven't touched the rear brakes. The drivers side also needs body work and some of the clear coat is flaking. $5000
