What I thought to do was drill the hole in the roof. Then bend the A pillar, leaving it a little long, and drop it through the hole. Then cut it off flush with the roof, and weld the plate to it, but so that the plate sits of the top of the roof, and can be sealed and bolted down. Then I will run a tube from the B hoop forward, and have it make a 70-90 degree bend downward, and connect it to that plate. Make sense? It would all be one piece then, but built in seperate sections, making it easier to bend and build
