Where the F did the roof rack come from and why isnt it a Yakima?!?!?
it fell off the back of a truck
screw yakima, its this brand http://www.safetydevices.com/
so you had to cut it down?
Its for series 2 so he had to section 6" out and then un-**** the drip rail mounts.
tried to see what you ****s were doing saturday and sunday, but nobody answered.
someone dumbass put that rack on a toyota and ****ed it all up. I've probably got 20 hours in it un****ing it up.
Replaced most of the body panels, might do the rear panels this weekend
http://www.flemcodesign.com/pics/bodwork/1.jpg
new seats
http://www.flemcodesign.com/pics/bodwork/4.jpg
ordered flares
http://www.flemcodesign.com/pics/bodwork/2.jpg
bigger than the series 2 flares I had earlier (the inside line)
http://www.flemcodesign.com/pics/bodwork/3.jpg
cut
http://www.flemcodesign.com/pics/bodwork/5.jpg
installed
http://www.flemcodesign.com/pics/bodwork/6.jpg
dude, i live 10 min up the road from you. give me a call sometime when you're working on ****
Damn, you've been busy!
Is that a rope limb riser?
dual purpose, it also has a stake for front yard dog entertainment
So I converted the warn 9000i to a regular 9000, replaced the burned up warn motor with a db electric replacement, threw out the warn solenoids and replaced them with an albright contactor, and now I've got to do something about the control. I can't find the warn control plug anywhere except for warn, and I really don't want the cable draped over the hood all the time. I can't find a dash mounted rocker switch that doesn't look like ****, this is the third best option. Its kind of chinesey, so it might not last, but its cheap.
http://www.roadlessgear.com/Merchant...J/PROD/R/RG630
12voltguy dash panel?? :flipoff2:
Instead of using the plug on the winch, can you wire it into the contactor box? It's not like you will take the winch off much, then you can also have the plug in the front if you want to use it while you are out of the cab.
Like Tommy showed those switches are pretty good, I picked up a momentary double pole at radio shack and made a little plate with indicator lights, it is on page 226 of my thread.
http://www.tamor.org/forums/showthre...Klogger/page16
Also, any power window switch can be made to work like a winch switch.
Karl there is no plug on the front with the 9000. I could take the socket off the 9000i case (that is missing the dust cap) and mount it somewhere outside , but I think the wireless will be good enough. If it breaks in some kind of winch requried for survival scenario I can start ripping speaker wire out and build a switch out of a coconut.
What is so offensive about this?
http://www.12voltguy.com/image.php?type=P&id=17596
I agree. I'll have one of those when I get the ****tybilt going again.
That reminds me, I have your dust cap, This year at Clayton during the 8-point spring debacle we had to use your winch, the retainer strap was already broken, I removed it to plug your controller in, and put it in my pocket, it has been floating around in my truck with the intention to return it to you some day. Next time a Dallas feg is in Houston I will try to remember to send it home.
Side note, can you use an old school 4 prong plug? those are just 4 pin circle trailer plugs that you can get at Vatozone
I could. I think I'll just hide the warn plug somewhere behind the grill
Do you know if superwinch controls are wired the same as warn? This is cheaper than buying the replacement socket from warn, and I'd end up with a spare control
http://www.etrailer.com/Accessories-...ch/SW2271.html
you working on it tonight?
maybe, I need to start tearing the axles apart. I got the correct seals for rovers with oil bath hubs and need to swap out the stock ones.
I gave in to the dash mounted control, though the wireless works fine.
Gate mishap took out bumper #4. Might be time for something heavy
How did the gate fair?
Where did you get the switches from for that?
Altex electronics in Addison!
What did you do for the plug on the front or did you wire it in?
The albright contactor is under the hood (it replaces all the relays), the control wires go off it to the cab where they are split to the wireless control and the dash control
Got Pics of the Disco at Cars and Coffee this past weekend. King of the Rovers!
http://i46.photobucket.com/albums/f1...r/8d3ea16e.jpg
http://i46.photobucket.com/albums/f1...r/1e36ffa9.jpg
http://i46.photobucket.com/albums/f1...r/0d831523.jpg
What Happened to the roof rack?
its still on the jig.
Non ****ed up rack
Much better. Did you actually drive around with the straps holding it on? This one is an original series 1 rack and not sectioned?
had to, that rack requires removing the stock rails. It is factory for a disco XD http://www.expeditionexchange.com/safetydevices/
If we buy you a dorkel for hanukkah will you rock it?
http://www.expeditionexchange.com/sa...s/DSC04713.jpg
Only if its nicer than the one I already got ;)
More ****. Tank skid, I'm putting the 96 tank on, it doesn't have a 5 gallon dent and I'd like to keep it that way. Used Rovertym shock mounts too
