I am going to need some 45s to get the feed line a little more vertical. I didn't realize once you push those hoses on those fittings, that it is not easy to get them back off.
The cooler is just going to be hung off the radiator, and be in the return line, above the gearbox, but below the resevoir.
Thes square cut washers provided do not really want to go into the brass fittings. The larger one though did fit in the 90degree fitting.
