Flex fans need rpm to move a good amount of air. How old is your fan clutch? From what I've read a stock fan with a good clutch should pull a lot more air, especially at idle, than a flex fan. You can also look into stock fans from other vehicles. I'm pretty sure I've read about a fan swap before where someone found a fan with more blades from a cadillac or something and swapped it in.
