There will be no dominating in Conroe, I won't even be the strongest guy from LA there!
Training went pretty good for my first time with these guys. Worked with their tire (675 lbs) for a few reps. I'm rusty on this one, I had gotten pretty good on the tire over the summer. I did a couple sets of 5 and tried to work on speed. Moved to farmer's walk at 280/hand. This went well also despite not working this in months. My pick up still sucks, but once I get moving I'm decently quick, so that's good. Grip isn't an issue, so I just need to work on getting faster from the ground.
New events were the yoke, chain drag and Atlas stones. Their yoke is a chain yoke (bar across your back like a squat, with a heavy keg suspended by chain at either end). I have no idea what it weighed, but it didn't feel heavy. That said, the chains made it very unstable, but it wasn't too bad. I have a 650lb. yoke as part of a yoke/farmers/sled medley in Conroe, but it's a fixed yoke. The chain was 550lbs, and I smoked this one.
Last but certainly not least were the stones. I worked on lifting and loading the 225 for a few reps, and the guys helped me out with some technique. I loaded the 225, 250, 290, and 315 to a 54" platform. I was able to lap the 410 but not load it. All in all, not bad for my first time touching a stone.
I haven't worked overhead with these guys, but I've been training it in the gym. Since I'll have a 275lb axle for reps in Conroe, I've been training that on my RE Upper day, and have a best of 12 reps with no set downs. If I'm allowed a set down, and I should be, I should be able to get a couple more since breathing is my limiting factor, not strength here. I hit 11 for two sets yesterday, and I felt like crap, so I felt pretty good about that.
I'm starting to feel a bit run down, and may be getting close to overtraining. I'll start tapering the volume down starting next week and see if that helps.
