I was able to get the broken 70 shaft out this afternoon. We found a long piece of 3/8" rebar and pushed it out of the axle. It was a fairly painless operation once we had a peice that was long enough and thin enough to go through the hole in the middle of the detroit. I don't know exactly how big the hole is, but I would take a guess and say that anything over 1/2" would not make it through.
When I went to install the new shafts, I found that they were the right length, correct spline count, but the wrong bolt pattern on the flanges. The pattern is a 3.56" spread on the axle, and the shafts had a 3.9" spread.Now I need to try and locate the correct shafts tomorrow. I am going to take the new ones down to Bryan tomorrow morning and see if someone can drill out the correct pattern on them (I should be able to weld up the existing holes with out too much trouble. Any thoughts on who would be the best place to take them to?
I am pretty sure the front slip shaft is down at the house, but I ran out of light to look for it, so I will be up bright and early to get the rest of it up to the driveway so I can get it all together.
