I measure the amc 20 the drivers side is 25" and the pass. is 26.5". So total length is 51.5" from flange to flange. I'm going to make the 9" the same dimensions.
I have wired wheeled the entire thing. Measured for where I am going to chop it, and removed shock/spring mounts.
I also order this truss today. For how cheap it was I couldn't resist.
http://www.nineinchracing.com/prodde...?prod=ALL68330
I'm going to get the alignment pucks and rod from Creighton, and Flem has some left over moser bearing ends from his build that I'm getting from him.
These are the plans for the 9" shave.
http://www.alaska4x4network.com/showthread.php?t=9104
