Finally got around to disassembling the rear axle. I had a little breakage in Arizona and we pulled out mysterious pieces with a magnet, then the magnet got stuck.
Looks like the shaft took out the bearing journal on the carrier, and also the inner race of the bearing. Glad I wasn't planning to reuse that carrier. Had to pull it because I need the gears to put on the detroit for the front.
