Page 16 of 61 FirstFirst ... 6 12 13 14 15 16 17 18 19 20 26 ... LastLast
Results 226 to 240 of 903
Thread: The TJ stands for Tate Jeep Buildup
  1. #226
    Sand Man Shaggy's Avatar
    Dec 2007
    San Antonio or Victoria
    Clayton is 6 weeks out. time to come up with a to do list
    -Transfercase Drop kit. (rear driveshaft bines up at flex)
    -Rear locker (weld)
    -Re-install back seat seatbelts
    -Get spare parts (front and rear driveshafts, dana 30 and 35 spare shafts)
    -replace broken bulb im one KC light
    -Rock sliders (if I have time)
    I think that is it... pretty short list
  2. #227
    ... TMatheaus's Avatar
    Nov 2005
    Bayou Vista
    i have a 1" rusty's tcase drop kit somewhere tate if you want that
    Tommy Matheaus '06
    210-323-2546
    2004 F-140 4x4 DD
    1990 F-150 4x4 in the works
  3. #228
    Dec 2007
    i have one already... came with spacer kit... didnt want to put it on... but i have to now. i will get rid of it when i order the atlas. the reason i need it is because i still have a slip yoak driveshaft... thanks though
  4. #229
    Dec 2007
    done-Transfercase Drop kit. (rear driveshaft bines up at flex)
    -Rear locker (weld)
    done-Re-install back seat seatbelts
    done-replace broken bulb in one KC light
    update
  5. #230
    Dec 2007
    picked up dana 30 shafts and hub asembly at the j-yard out of a 91 xj last week. just pulled my tj shafts to make sure they are the same and they are. I pulled the plastic off the passanger rocker and found a dent. am going to start sliders after i eat an early lunch. i tore a dana 35 down at the yard the other day most of the way but ran out of time before they closed. I need to get back out there and grab those shafts. Also need atleast a rear spare driveshaft and to tear my dana35 down and weld it up. dont have many days off between now and the trip so hopefully today is productive
  6. #231
    Dec 2007
    pulled the dana35 this morning and cleaned it in the parts washer. oil in it was factory and still very clean. Going this evening to use an uncle's mig to weld it up. didn't think my arc welder was up to it with my rusty skills.
    also pulled my driveshaft to compare it to the spare one I picked up. As I was afraid of it is 1.5" longer and needs to be cut down. Will knock that out after I finish the sliders.
    a couple pics of the sliders mached up... nothing is welded up yet
  7. #232
    May 2003
    Htown
    Damn, that's fast!
    So you loose, I win!
  8. #233
    Dec 2007
  9. #234
    those look almost exactly like the old ones I had made. . .
    http://tamor.org/forums/showpost.php...0&postcount=43
  10. #235
    Dec 2007
    well there are only so many ways to make them
  11. #236
    Dec 2007
    got them all welded up now. need to run and grab some paint, drill holes and mount them. havent decided how many bolts to hold them up with yet
  12. #237
    Aug 2002
    awsome
    what did you have for lunch? Was it good?
    How many stop lights did you hit on the way to buy paint?
    Did you get anything else while you were out?
    sweet blog!
  13. #238
    Dec 2007
    [QUOTE=uglyota;244065]awsome
    sweet blog!
    [/QUOT
    2 sandwitches ... not bad
    2 lights and 1 stop
    nope just paint
  14. #239
    Dec 2007
    i took a pretty bad dood video of the paint drying... wanna see it?
  15. #240
    better whatch out, you wont be able to run those marathons anymore with that dyet.
