That badass Robbie
I may be mistaken but I think that kit is like a self-tuning speed density system or maybe better described as a mass air without a MAF sensor?
it is true speed density. self tuning is easily done when you eliminate ignition control and use a wideband on a naturally aspirated engine. Pretty hard to burn holes in pistons or break rings that way, and if it does you can blame it on the springs in the distributor.
It uses the wideband and efi computer to adjust fuel tables on the fly instead of a human interpreting the data while trying to hold on to a laptop while riding in a square tired death trap and helping the driver look out for the man and his radar.
can't see the pic. i'm assuming it is FAST EZ-EFI?
Mounted the tires the other night, the bias ply's are much easier and don't require a strap to seat the inner bead.
Got the new front driveshaft installed and took care of a couple loose ends. Drives really well with the Iroks.
I'll install the fuel injection and other stuff in the next couple weekends after the semester starts.
It's ready for Spring Creek tomorrow...
are you going to upgrade to a 1350 front shaft?
if i lwarned to read then i would have to do homework, thats not gonna happen
looks much better.
tall and skinny is the way to go
