4:1 kit is the way to go and will be the cheapest and easiest route. The kits are like 500-600 depending on what offers the manufactures are running.
Trans swap will cost quite a bit more you have to source the trans, rebuild it, find goofy or hard to find adapters, then on top of all of that you will most likely have to build new driveshafts.
As far as regearing the axles you gonna be hard pressed to do that for 500 by the time you buy both sets of gears, install kits, and new carriers. Plus what size tires are you running 33's? 4.56 would prolly be what gears you would swap to and might be to much for highway cruising. Also you aren't improving your gear ratio by that much.
My 0.02
