Page 18 of 42 FirstFirst ... 8 14 15 16 17 18 19 20 21 22 28 ... LastLast
Results 256 to 270 of 628
Thread: Who had March 14th?
  1. #256
    May 2003
    Htown
    fun fact
    77 cat
    78 no cat
    79 cat
    the whole modified family came about because of lame emissions stuff.
    So you loose, I win!
  2. #257
    Aug 2002
    Quote Originally Posted by Eckert View Post
    grant it its a '79 truck, so the basis on how it works is simple to understand. but im pretty sure i pulled 3.82 miles of vacuum hoses and other emissions related bull**** out from under the hood.
    HP, if you want it to run better. pull the 80lb cast iron intake and put on a aluminum one w/ a appropriate 4bbl carb.
    corrections: "Granted" and "2bbl"
  3. #258
    true, The good thing is, you can just take it all off and plug the holes and it doesn't affect anything..........except emissions
    F*ck off cj.
  4. #259
    Chief
    Sep 2008
    Tell me what your oil pressure is and I'll tell you what oil to use!!! I'll respond to your pm when I'm back in Texas and not drunk.
    I'm running 10w30 castrol high mileage. Cold it will idle at around 80 psi. Cruising it will bounce between 50-60. Hot Idle will usually be a good 30. I hear those numbers are pretty healthy for these m block motors.
    Quote Originally Posted by Hot Pocket View Post
    Now that you mention it, when I first installed the new battery and new alternator, I put the voltmeter to the battery and was reading like 17.8 volts... It seemed a bit high, but I didn't think twice about it until now.
    A month later with the new alternator and battery, and it still charges up to 18 volts. I feel like that is a lot, Anything to be concerned about?
    Quote Originally Posted by uglyota View Post
    but his truck's not lifted, right? DW shouldn't even start if the caster's right (i.e. stock), tires are balanced, toe-in is set, and ball joints and tie rod ends are tight. My guess is that this rig just needs some maintenance first (ball joints/TREs)
    What brand for ball joints? Anything I should stay away from? I figure I might as well knock them out while I'm doing bushings.
    I finally found the electrical short, and am kicking myself for not realizing it earlier. The PO had tried to wire up his brake lights/tail lights/ reverse lights via 6 different trailer pin adapters. Once I got all that crap pulled, the battery stopped losing charge.
    Now, I need to wire up the taillights, brake lights, etc. The haynes manual is difficult to work with, but it's getting the job done. I found some useful diagrams on this site if anyone is interested.
    http://7879blueovalbronco.com/forums/showthread.php?t=6
  5. #260
    with your mom
    moog
  6. #261
    or Spicer. Not oriellys house brand
  7. #262
    Chief
    Sep 2008
    Quote Originally Posted by JBrown89 View Post
    Is it true that Raybestos is just rebadged spicer?
  8. #263
    Chief
    Sep 2008
    I need some help.
    I was replacing the track bar bushings today and I was able to get the nut off of the front of the trackbar bolt. The bolt is stuck in there, I think it has been wallowed out from wobbling so many times. What are my options? Sawzall is out and buy a new bolt?
    Here is a picture.
  9. #264
    Why can't you pound it out with a hammer? Will the bolt turn at all?
  10. #265
    here's the proper tool.
    F*ck off cj.
  11. #266
    Chief
    Sep 2008
    The pitman arm is in the way of hitting it with a hammer. I tried
  12. #267
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    That bracket/shock mount is held on with two bolts take it off and pound it out.
  13. #268
    Turn the bolt in reverse to back it out, it will work it's way out until the threads are flush with the bracket, then grab the bolt with pliers and wiggle it out.
  14. #269
    Aug 2002
    yep this. If you can get your impact on it just keep it spinning and push on the end with a drift or something if you can until the threads catch and it will spin right out
  15. #270
    Chief
    Sep 2008
    I think I explained the situation incorrectly. The bolt is completely wallowed out, when I try to turn it from the other side, it does not go anywhere. I will have to cut it out and replace it.
    I have checked rockauto, and I believe this is the right part I need to replace it with.
    It is under 1979 Bronco->400->Suspension->Trackbar.
    Part number 88913259
    Also... gonna need a new radiator
