fun fact
77 cat
78 no cat
79 cat
the whole modified family came about because of lame emissions stuff.
I'm running 10w30 castrol high mileage. Cold it will idle at around 80 psi. Cruising it will bounce between 50-60. Hot Idle will usually be a good 30. I hear those numbers are pretty healthy for these m block motors.
A month later with the new alternator and battery, and it still charges up to 18 volts. I feel like that is a lot, Anything to be concerned about?
What brand for ball joints? Anything I should stay away from? I figure I might as well knock them out while I'm doing bushings.
I finally found the electrical short, and am kicking myself for not realizing it earlier. The PO had tried to wire up his brake lights/tail lights/ reverse lights via 6 different trailer pin adapters. Once I got all that crap pulled, the battery stopped losing charge.
Now, I need to wire up the taillights, brake lights, etc. The haynes manual is difficult to work with, but it's getting the job done. I found some useful diagrams on this site if anyone is interested.
http://7879blueovalbronco.com/forums/showthread.php?t=6
moog
or Spicer. Not oriellys house brand
I need some help.
I was replacing the track bar bushings today and I was able to get the nut off of the front of the trackbar bolt. The bolt is stuck in there, I think it has been wallowed out from wobbling so many times. What are my options? Sawzall is out and buy a new bolt?
Here is a picture.
Why can't you pound it out with a hammer? Will the bolt turn at all?
The pitman arm is in the way of hitting it with a hammer. I tried
That bracket/shock mount is held on with two bolts take it off and pound it out.
Turn the bolt in reverse to back it out, it will work it's way out until the threads are flush with the bracket, then grab the bolt with pliers and wiggle it out.
I think I explained the situation incorrectly. The bolt is completely wallowed out, when I try to turn it from the other side, it does not go anywhere. I will have to cut it out and replace it.
I have checked rockauto, and I believe this is the right part I need to replace it with.
It is under 1979 Bronco->400->Suspension->Trackbar.
Part number 88913259
Also... gonna need a new radiator
