With one tire in the air and 4wd engaged I could not find any slop in the u-joints or bearings. Also checked ps fluid and it's good. The noise seems not to be coming from either wheel, can be felt in the steering wheel when turning at speed or parked.
Any other ideas?
You should check u-joints with tires blocked and transmission/tcase in neutral
