Page 15 of 17 FirstFirst ... 5 11 12 13 14 15 16 17 LastLast
Results 211 to 225 of 241
Thread: Project: Nasty Bastard
  1. #211
    Oct 2002
    Poth, Tx
    When are you going to fix the color?
  2. #212
    Quote Originally Posted by redcagepatrol View Post
    remind me to stay away from this "Klogger waiting to happen" in Clayton
    Last year as I recollect the Klogger was running when your craptrol was broke on the side of the trail. Then you had to summon the power of the blue oval by installing a ford coil on that thing
  3. #213
    Anyone know if chey hydro clutch systems use a plasctic spacer on the mounting surface for the slave cylinder that is attached to the bellhousing?
    Krebs should know about this, he converted his blazer to a standard with hydro.
  4. #214
    Who???
    :blackflipooff2:
  5. #215
    Quote Originally Posted by eight View Post
    harbor freight orange?
  6. #216
    True Hollywood Stry
    Sep 2003
    somewhere in texas
  7. #217
    Aug 2005
    Houston or a drag strip
    The rear stud came loose from the housing due to fawked threads while the front stud was ok but slightly bent, probably due to shims but I need them.
    I'll probably go the u-bolt route since it's the most shim friendly and remove the least amount of housing webbing possible.
    1974 CJ5-The BarnBurner
  8. #218
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    4 wheels again, whoop!! I still have a ton of work to do, but I am getting there. I was on crack thinking I could have had this thing done by clayton.
    I also reached my goal of beating Tate in having the bastard on 4 tires again.
  9. #219
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    Before one of you gun nuts wet yourself its a pellet pistol..
  10. #220
    Sand Man Shaggy's Avatar
    Dec 2007
    San Antonio or Victoria
    I would have had it on all 4 tires a while ago if ballistic fab would send me my damn towers. I really don't have much left. Bleed brakes, set 60 gears, hydro lines, cross member, driveshafts, t-case shifter, mount shocks, and exhaust. Probably more but that is all I can think of
  11. #221
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    Krosby Kustoms kicks off-road designs ass, we make our own chevy draglink to clear the engine crossmember. It was actually really easy to make and only took about 30 minutes to make.
    link to the offroad design one
    http://offroaddesign.com/catalog/Dana60crossover.htm
  12. #222
    You are aware the ORD one is like 1/4 wall and threaded right? Not so sure about yours. For the record, my dragling is made from a rockwell tie rod, so its legit
  13. #223
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    I have an air over hydro setup on my bender .250 is not an issue.
  14. #224
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    Name:  center console.jpg
Size:  58.9 KBName:  shifter coverplate.jpg
Size:  59.8 KBName:  new floor.jpg
Size:  50.0 KBName:  seats and center console.jpg
Size:  78.5 KBTook some time off of working on the suspension and drivetrain crap to finish the floor, install the new bucket seats, and make a shifter/cupholder console so that I could double my current cupholder ratio and also have a good mount for the cable shifters.
  15. #225
    looks good I like the console
