that will take a set of L92 heads as well. From all the build ups ive read, L92 heads, ls6 hot cam or equvalent, car intake and a proper tune should make between 460-500 depending on cam. The only difference between in the LQ4 and the LQ9 are forged pistons and less then a point of compression. The only issue i see with those motors are how fast they rev and requiring 2500 to 2800 stall
i have never seen that they had forged pistons? u sure? just about zero oem motors come with forged pistons due to the loose cold piston/bore requirements. much less a motor that has had wicked bad piston slap issues in the past
