Page 163 of 211 FirstFirst ... 63 113 153 159 160 161 162 163 164 165 166 167 173 ... LastLast
Results 2,431 to 2,445 of 3159
Thread: Random Tech Questions
  1. #2431
    Hazaa Fredo's Avatar
    Why don't you make something that looks like the spacer lifts for the newer strut trucks? Tubing and flat plate. Either that, or check and see if it's the same pattern and just buy them.
    http://www.topguncustomz.com/Store/G...view=249061884
  2. #2432
    metal depot or online metals, order four individual 6"x1" round bar 6061, put in drill press with hole saw.
  3. #2433
    Awesome, this is what I was looking for
  4. #2434
    For something that small you could use a piece of solid round stock and just drill the hole to the rightsize.
  5. #2435
    Who or where could cut the roundstock 1" thick?
  6. #2436
    Jan 2010
    I'll pay for the metal if you cut it out with a jig saw with one blade.
  7. #2437
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    If you go ed's route find someone with a bandsaw/chopsaw to cut it for you. If flems you might try a machine shop.
    Or dont be puss and use a grinder with a cutoff wheel
  8. #2438
    if you go my route they cut if for you, you are ordering a quantity of 2 @ whatever length you need. its all automated and goes right from the webserver to the bar feeder, they don't have someone add the cuts up and give you one piece.
  9. #2439
    I'm guessing aluminum would be ok for this type of spacer?
  10. #2440
    Sand Man Shaggy's Avatar
    Dec 2007
    San Antonio or Victoria
    What is the shift pattern on a tera-low case? Standard case is 2h-4h-n-4l. I have shifted through this case over and over again and I get 4-4-n. That is with no 2 at all and possible 4h and 4l on the same side of n. What is wrong here.
  11. #2441
    Nov 2002
    Tx
    Mine is same as stock 2 4h n 4l.
  12. #2442
    did you put the case together yourself? make sure the shift for is in properly.
  13. #2443
    Dec 2007
    This is busa's case. Came out of his and bolted into mine. The only thing I installed in it was the speedo sensor. I don't see how that could cause any problems
  14. #2444
    how are you verifying the ranges?
  15. #2445
    Dec 2007
    Don't know if they Are high or low but I can tell if both outputs are engaged or not. I will pull the speedo sensor and see if anything weird fell in there in transit and is acewing things up
