It came as a kit. I'm not sure if i'm going to use them. Without them it's a 1" bolt, with them it's a 3/4" bolt. It gives it 34* of rotation with the high misalignment spacers.
If you are worried about misalignment, just ad an SAE washer with a bevelle ground into it on each side of the hiem. Also build your bracket with a slight angle in them so the hiems are centered, it's ok it took a while for a bunch of 16 yr olds to figure this out as well.
So here are the things I haven't addressed yet.
Conversion Joint or New slip yoke
-can I buy a whole new slip yoke for a 1350?
Brake Lines
-I already have a braided stainless line that comes from the frame but I don't know if I'll need any adapters to go with it.
Trac Bar
-thinking of using the stock superduty one with a homemade bracket at the frame.
Drag Link
-Hoping the stock one will be the right length
Still need to get
wheels from frick
-Ryno, do you want the hub caps?
Brake Pads
Turn the rotors
classic ammco lathe... there heavy as hell too..
Ordering 2 more heims. Drew this up on inventor, just an idea.......
can you make the lowers hang down lower? The closer to the ground, the better for an off-road rig...
