Beadlocks, so I have a set of 16.5" Trail Ready Beadlocks. 3 of the 4 are fine, but I have one that I can not get to seal worth a shat. Tommy got it to seal for about 2 days, but then once it leaked down it started leaking really bad. This weekend I took it apart, cleaned the crap out of the tire and rim, bought all new bolts, torqued them down properly (cross pattern sequence to 20 ftlbs) and the SOB still leaks. It seams to be from the same spot on the beadlock (not the tire, so it is not a rip in the tire). The aluminum bead lock is pretty coned.
Suggestions?
