Page 60 of 132 FirstFirst ... 10 50 56 57 58 59 60 61 62 63 64 70 110 ... LastLast
Results 886 to 900 of 1980
Thread: Sloth
  1. #886
    Hazaa Fredo's Avatar
    ...and there it is. My work here is done.
    Really Tommy, I know Ryno mentioned a crossmember earlier in this thread. It's a good idea when you have a stamped frame rail. I don't think you're going to "wallow out 12 holes", but you might rip the side of the frame right out.
    Also, I don't think you and I have wheeled together, but you're obviously absolutely right, I'm an asshole. I don't help people at all.
  2. #887
    The reason we didn't do any of those things is because the drivers side is cluttered with wires, brake and fuel lines, fuel pump and filter, 205 support foot, and the transfer case crossmember. I barely had enough room for a washer, lock washer and nut.
    Down the road i'll be doing a 205/1356 doubler and will build a whole new crossmember then. When I do that i'll tie the r/a mounts into it.
  3. #888
    with your mom
    You need to watch what you say to people tommy. There are many on here, just as with any other site, that mean well but just come across in a manor that will make a thin skinned person butthurt, for example me or fred. For someone that just learned to weld and has a history of makin dumbass mistakes working on their vehicle, you might want to step back and take some advice from others. Even though all the young guys in this club, including myself at times, have the idea that all the old tamorites are the ones running off the newbs, they are still the ones with the experience and knowledge to help this dying club keep its head above water.
    As for boxing the frame or building a crossmember, ya it might be a little more work and tough to work around all the **** in there, but overcoming those issue is what being a good fabricator/builder is all about. Just as I told you before, take the time and do it right the first time or you are going to get pissed when **** goes wrong on something that could have been prevented. How hard would it really be to make a bend quick crossmember or make one out of square? The factory had one, but I guess the designers were dumb and dont know how to make a vehicle last 30+ with a monkey driving it.
  4. #889
    Nov 2002
    Tx
    Karl and I have both had to straighten/repair bent frames at the radius arm mount. You're bracket is plenty beefy, but that doesn't mean squat if the material it's bolted to is 35 years old and abused. Granted, a ttb probably puts more side load on the radius arm bracket than a straight axle with panhard, it's still a good idea to box the frame.
    And we all know Fred's an asshole. Only reason he's here is he's the Major's cousin.
  5. #890
    Maybe the people that mean well should watch what they say too... just saying
    but lets try this again, and I guess my last post got lost.
    Could the frame break somewhere around the mount? Sure
    But after having done a set of James duff arms before and seeing them last fine for the last 4 years I doubt tommy will have much problem.
    Reasons for not boxing the frame:
    Save time and money of doing it right
    In nearly every Ford frame I've seen boxed, and no cage, it ends up cracked on the edge where the boxing ends or begins. C channel frame like these are designed to have a certain amount of flex and by strengthening adds stress to the adjacent areas.
    Reason for no crossmember:
    Time, money, added hang down
    Who has experience with the RA mount breaking the frame? where did it break at? why did it break?
    In my experience with extended RAs on fords this set-up has worked fine for many years and boxing the frame has normally lead to a much worse result. Also when I was researching both James Duff and Cage recommended not boxing the frame and said that a cross member was unnecessary, in fact the Duff arm mounts are made for the early bronco boxed frame and their instructions were to cut off the inside ear and bolt up.
  6. #891
    My rear leaf spring mount is not boxed. No probelms. I had TTB extended arms for many years. Also, no problems.
  7. #892
    Brazos County
    The bracket is fine, just keep an eye on the frame. I will scrounge around and see if I have any pics of my frame crack.
    Ps Fred - I miss you. You complete me.
  8. #893
    Brazos County
Size:  59.7 KBName:  DSC00723.jpg
Size:  80.1 KBName:  DSC00543.JPG
Size:  142.7 KBName:  DSC00725.jpg
    Quote Originally Posted by Seth View Post
  9. #894
    Sand Man Shaggy's Avatar
    Dec 2007
    San Antonio or Victoria
    I broke the frame on my bronco 5 times before I finally boxed it. I am not saying yours will but it made a difference once I did.
  10. #895
    1980 Bronco frames were known to have alot of issues right?
    Travis, I do not see why a boxed frame would weaker. It would probably not be a bad idea, but I do not think it is totally necessary. We shall see.
  11. #896
    DFW
    From everything I have heard second hand about Tommy's driving style... I would want that **** as plated, boxed, and reinforced as I could get it!
  12. #897
    He has been wheeling a fullsize rigs on little axles with bro-tires. He hasn't really wheeled hard because he hasnt been able too.
    Am I defending Tommy?
  13. #898
    What I'm saying is that I would not feel comfortable boxing the frame unless we did the whole frame and new cross-members or cage. And it would never get done being that we only get to work on this thing maybe 1 day a week.
  14. #899
    The klogger's frame rolled in where the drop down radius arm bracket was almost hitting the driveshaft. I did not box the frame. I hooked my winch to it with a snatch block and straightened it out. Then I took a piece of 2.5" square quarter wall tube. With the frame still being slipped apart I put the piece of tube in between the 2 radius arm mounts. Again this was with TTB, and like BDR said TTB probably puts more load on an axle especially with drop radius arm mounts.
    Frick made a giant box like structure for his frame, you might ask his opinion, but I doubt you will since you have a **** attitude.
  15. #900
    Yeah I asked frick about it yesterday.
    If it breaks it breaks, ill weld it back up and build it stronger.
