Results 1 to 15 of 1980
Thread: Sloth
Threaded View
  1. #11
    Planning a switch panel to replace the old center section. I'll make it out of some thin stainless or aluminum. Safety switches for the Fuel, Ignition and winch. Master on off switch and switches with the rubber boots on them and open indicator lights on all of them. I'm going to really get into my wiring soon. It is getting to the point that it's a fire hazard. So i'll have relays going to all of the single switches.
    Rewired the check engine light after the near fire at k2. Put a new light in there that hasn't been crushed by a rotor so it works.
    Went through all of the under the dash wiring and made it alot safer. Also a new alt belt.
    put the tester on the bronco at work today. 925 cca out of the 880 cca battery, 14.2v at idle without load, 14.1v at idle with all of my lights and my heater on. 42mv ripple, 730ms starter time.
    F*ck off cj.
